Ok folks, I'm jumping on this thread now. I had the same issues at Nixt (and others it sounds) last summer, but I thought I solved them by replacing / cleaning one of the many things Nixt tried. Low and behold, she started acting up again this weekend after over 6,000 miles with no issues! Bucks and misses like crazy but not at start up. Only after about 3-4 minutes of running. I also noticed a loud 'sucking' sound coming from the air intake box (actually have an Airraid tube). When the rpms are held around 2000, the engine actually pulsates and surges around 500 rpms (from 1500 to 2000). At lower rpms, it bucks and pops out the air box until the rpms get up then the bucking stops but it still is not running 'smooth'.
Here are a couple thoughts and ideas that I'm going to try. Any thoughts on these?Maybe all of us with this issue may stumble upon a connection and figure it out!
-clog in the fuel line / tank / fuel pump? can't imagine it's a bad pump since I didn't have an issue for over 6K miles
-bad / clogged injector
-I sure hope not, but a computer issue?
-how about something to do with the temp sensor? My temp doesn't act normal. I get huge, quick movement in the needle. It never overheats but will jump from 120 to 210 in about 3 seconds. Maybe this is throwing something off. I'm not exactly how the chokes work on these later model engines.
I do notice after I have this issue, the metal tab on the rotor is highly fouled. Does this give anyone a hint?
Thanks! I hope we get to the bottom of this!
