00_cherokeexj
- Thomston, CT
Hey guys new to the forum.. I have a 00 cherokee with a 95 engine in it... Did a compression test not to long ago and everything checked out the way it should.. The misefire doesn't happen all the time it will only happen when the jeep gets hot after I'm beating on it or if I drive it for along time. If I turn it off for a few min I'll get a really bad misefire where the jeep wont even start then once the motor cools off it will finally fire with a rough idle then clear its self up. If anyone has an idea what may be causing this any help would be great Thank You...
