RidgeRunnerXJ
- Brighton(ish), CO
Sold my XJ, don't need this stuff anymore.
35 and 37 tooth speedo gears, short shaft, will fit '93 - '01 XJs. Will also work on TJs and ZJs I beleive. - $20 each
Speedo Sender Unit, from a '99 XJ with a NP231, should work on other Jeeps with a np231. - $25
4.0l motor from a '97 XJ, ran when pulled, don't remember the milage, pretty high though, 180k ish IIRC. Was going to build a stroker with it. Includes intake, exhaust manifolds, fuel rail, alternator, and starter. - $100
Stock replacement steering stabilizer, MOOG, lightly used. - $10
Used Unit Hubs, off a '96 XJ, still good. - $20 each
C8.25 housing with 29 spline carrier, 3.05 gears. Open, no shafts, no brakes, carrier bearings are shot. - Take it for a 6 pack of something from Great Divide.
Dana 30 housing, 3.05 gears, open. No shafts, no hubs, UCA brackets cut off. Used as a pattern to fab a truss. - Free if you can use it.
Rear Hatch from a '97 XJ, Emerald Green, complete with glass, wiper motor and tan interior panel. Will fit '97+. Some scratches, no dents. - $75
Front Fender, drivers side, '97=, White, no dents. - $30
Rear interior door panels for '97+, Graphite color, for manual windows. - $20 for the pair
All parts are located in Broomfield.
Dave
3o3-8I7-nineO45
Dave
3o3-8I7-nineO45
