Hi all,
I recently bought an 01 4x4 XJ with 180K miles on it. I changed all fluids, flushed cooling system and replaced rear main seal, oil pan gasket and valve cover gasket about 1 month ago. I only have a few hundred miles on Jeep.
Yesterday, one of the PCV valve elbows disintegrated when I was changing vacuum lines (running down a vacuum leak). So I pulled the valve cover because I am basically having to chip the grommets out because they are so brittle and cracked. That is when I noticed pic related on the underside of the valve cover over cylinders 5 and 6. I DID NOT notice any milky residue like this when I changed the valve cover ~1 month ago and the oil and coolant looked normal when I drained them. Also I tried to take a pic of the valves as best I could. Thoughts? Should I be concerned, what to do, etc?
