Prom3theus
- Cleveland
Mercedes 3.0 diesel (5cyl) engine swap
Hey guys,
I have a good opportunity to get a Mercedes 3.0 turbo diesel from a friend, and I thought it would be nice if I can replace my 4litter. I was wondering if you can help me finding more info about this swap. I could only find out info about the 5cyl Mercedes (but not enough) or 4bt or vw tdi.
Regarding shifting for aw4, I dont mind buying the kit and manually switch gears. I'm also aware that the 3.0 might be heavier and I may need different springs in front.
Do you folks know where the engine mounts and transmission adapters could be purchased from? Do I need anything else other than those (except wiring)? Any other hints/suggestions?
Btw, I have a 99 with 3 inch lift and 31s.
Thanks a lot!
Hey guys,
Thanks a lot!
