MasterPull
We make rope cool
- Bellingham, Wa
Master Pull is giving away a 11/32" X 100' Superline XD on Facebook!
http://apps.facebook.com/ss-efkp-dniclep
•Highest abrasion resistance and durability
•High breaking strength
•Braided cover prevents all grit and dirt from damaging core
•New and improved pre-spliced eye offers better strength
•Heavy duty stainless steel tube thimble won't rust or corrode
•Kevlar heat guard offers best protection against drum heat
Superior abrasion resistance
When rigging a vehicle extraction, open weave synthetic winch lines are subject to dirt and sand getting lodged in between fibers and strands of the line. Over time, abrasive elements will wear down the fibers of the rope, decreasing the performance and breaking strength. The entire Superline® XD synthetic winch line is over braided with Dyneema fiber to prevent this type of abrasion, which greatly increases the longevity of the winch line. The cover also gives complete UV protection.
Unrivaled strength
The inner core of the Supeline XD is the same pre-stretched Dyneema rope used in our Superline® series of winch lines. Like the Superline®, the Superline® XD has breaking strengths unrivaled by any other conventional Dyneema winch line.
Note that the breaking strength is measured from the inner core as the outer cover does not increase the breaking strength, just the durability of the line.
To enter, you have to "Like" Master Pull on Facebook. If you already Like us, then just fill out the form. Drawing will be 3PM Pacific on Monday November 26th.
Good Luck!!!
Daren.
Unrivaled strength
Good Luck!!!
Daren.
