lawsoncl
- North Idaho
Never thought I'd hear "Saturn" and "Reliable" in the same sentence! I have done the trick of Sea Foam in the cylinders to help free up stuck rings. Basically the same thing, naptha and a light oil.
When compared to Kia and reliable, Saturn and reliable is huge. We've been stranded by that POS Kia more times in 1 1/2 years and 29,000 miles than the Satrun in 16 years and 250,000 miles. I'm not kidding or exaggerating.
It's not that I loved the Saturn, but I had to respect how it just kept going and going with nothing but 2 alternators, 2 serp belt tensionor pulleys and normal maintenance. I was never into the engine or trans. When I sold it it was still running fine.
Had several friends who were big on Saturn. From what I saw first hand it was well built and one of the most reliable American car brands for a good number of years. Which is of course why GM killed it.
I've used MMO in my airtools and had good luck with SeaFoam when I bought this current Jeep. One thing, if you're going to pour it directly into the intake to clean everything out? you might want to do it BEFORE you install your brand new catalytic converter.
Don't ask me how I know.
How do you know?
LOL.
Sorry, could not resist that one.
Good recommendation. Same goes for the O2 sensor.
The forums recommended pulling the spark plugs and pouring a couple of tea spoons of MMO into each cylinder and let it sit overnight. The next day turn it over a few times without the plugs to spit any MMO out. Put the plugs back in, fire it up and then change the oil.
To those in the know, would this procedure work for curing leaking valve stems? My #3 spark plug keeps getting fouled up after less than 5k miles due to oil leaking in.
I read somewhere on here that if you need to replace the guide seals, chances are the holes are warped anyway and you'll need machine work to get good seals. Any truth to that?
