So for further reference for people who might google this later, here is what I think has happened. I cannot confirm any of it yet, but it's an educated theory:: About 18-24 months ago I blew the upper radiator hose. Replaced. About 4-6 months later I blew the lower radiator hose. Replaced. Had lots of trouble getting all the air out of the system. (There is a service notice on this problem. It's a PITA.) Failed to notice that under pressure the block-side clamp of the lower radiator hose was leaking under pressure, ran low on coolant and engine overheated. Testament to the engine that it took that long, since I poured back in almost 1.5 gallons of coolant. Happened again a second time after I took it into to the shop to have it pressure tested. So, overheated twice. Combined with strong anecdotal evidence that the heads on the early 2000 models had a strong likelihood of cracking especially after overheating. I believe that after the overheating the head cracked slightly and started to leak coolant. This coolant got miniamlly into the oil and was being consumed in the cylinder. The consumption was being masked by small coolant leaks in various places (overflow tube, etc.) The assumed coolant in the oil began to eat the bearing surfaces and caused them to wear out, opening the tolerances and causing the drop in oil pressure when both the oil got to temp and the entire engine reached operating temperature. As soon as I save up enough money to do a rebuild / swap I will be able to confirm this story.
