jeeptec
- atascadero california
i have an 87 with 6.5 inch lift. Tera flex long arm kit that uses lower long arms and short uppers arm in the stock location.i going to turn the system into a true radius arm.turns out talking to Tera flex they highly recommend this modification with this amout of lift to prevent front u joint bind. what im asking what material should i use to make the mounting brackets on the lower control arms 3/16 plate or 1/4 inch plate.
