ok, I'm running a 93 block with hesco's kit, bored .30 over, their aluminum head, 62mm tb and spacer, ford 24lb injectors, hesco adjustable fuel pressure regulator, stock intake (91), banks pos header (cracked 4 times now), stock pipe from header to cat, 2.5" high flow cat, 2.5" 70 series flowmaster, 2.5" tailpipe. aw4 auto behind it. and dual electric fans.
off the line it takes off, great pull, mid range it lags, then takes off again in top end,
what can I do to get good power and pull through the midrange where it is lacking?
