VaBeachMike
- Virginia Beach, VA
Installed a RE Street Ride 3.5 Inch lift on my 2000XJ. It was a PIA to install, bolts breaking everywhere! The kit included the new rear leaf springs and shocks. While installing I installed new U-Joints on the read drive shaft. The spring really set the thing up in the air. I now have a vibration in the rear drive train. The angle on the front u joint seems extreme. Looking for soluitions or suggestions. I guess the next thing I need to do is use some degree shims and see if I can change the angle. Any suggestions on what might be causing or correcting the problem?? Thanks for the help in advance. Mike :doh:
