I am in Michigan yes, mid thumb area to be more precise. I wasn't planning to do any work on the trans anytime soon, perhaps once I get the rig done though and get some miles on it when I am finished, I want to make sure everything is going to run good together and that I won't have any issues before I get that involved in rebuilding that kind of a precision component. AS of now I am only planning to get that detailed on the t-case, but that is a fairly simple job so I know I can do it. Trans has just a few more parts than that so will wait and learn and save up for a rebuild kit. That may sound a bit redundant to build up without rebuilding it, but I just can't rebuild it right now... It is time and money I don't have presently... My 8.8 is supposed to run the 75w140 or so autozone told me anyways. Friend of mine is going to get me some that is premixed with the LS additive from his work for axles. Would I be able to use the same stuff in the transmission? Or would the 20w-50 be better do you think? FOr the 20w-50, would that be like a good year round oil to use? OR would something else be better perhaps?p/QUOTE]
Understandable - but a gearbox is easier than a slushbox. Hell, if you can handle a transfer case, you should be able to handle a gearbox - just make sure you have a good manual (let me know if you can't find one, I'll see what I can come up with. Hit me backchannel on that.)
As long as the gear oil is safe for use with Yellow Metal, the LSD FM additive won't harm anything. I did the same thing with my Peugeos before I finally got an AX - the LSD FM (two of the five XJs I had had it) that I added to gear oil out of hand won't harm anything, and actually helps function as an anti-scuff additive - like the organometallic salts in engine oil (ZDDP being most common) used through API Service Specification SL.
Not having the anti-scuff won't cause your transmission any trouble, but you'll want to find SL or earlier for your engine - or stock up on GM EOS to add at
each and every oil change where you fill up with API SM.
Trust me on this.
Since your axle oil is likely to be a GL-5, and probably a synthetic (from what you're saying,) just check the label to see if you're good with copper & alloys (yellow metal.) If it's not on the label, check the manufacturer's site. If you don't see it there, use something else. The presence of the LSD FM won't make up for presence of sulphur-based EP lubes - if you've got the latter, you're still going to dissolve your synchroniser rings.
If you want to use engine oil, try 10W-40 first. It will get you through the winter, and will probably work well for the summer. If it doesn't, go ahead and step up to 20W-50, but monitor everything during the winter (same reason - I know how cold it can get up there...) When I had my Bug in northern IN, I'd replace one quart of engine oil with one quart of Marvel Mystery Oil for wintertime oil changes (air-cooled engine with magnesium crankcase and aluminum cylinders - damned thing was a bear to get warmed up on a winter morning...) and that helped. I figure you can get away with doing the same thing in your transmission in about the same ratio - one part in four.
I would like to keep it as smooth a ride as I can, with the lift and swampers I am running, I am expecting some so would like to do what I can to keep the noise down some. I think for the mount I will see what I can find in the elastomer material, poly would be ideal, but I think the elastomer would probably be better with a slight amount of "give" to help better control noise and vibrations... I am not planning at all to do engine mounts. Again, more time and money I just don't have. Will probably do them whenever it is that I rebuild the trans though. The PO was the original owner, he daily drove it for work which was just about all highway driving so I would tend to think (could be wrong though) that it should be in decent shape inside though. Still a ton of miles but still...
If you're not going to change the engine mounts, get the elastomer transmission mount - save up to change all three this coming summer anyhow (it's not that much of a job, and if you change one of the three when the other two have heavy miles on them you're going to lose mounts inside of six months to a year anyhow. Be ready.) Poly
requires that
all mounts be replaced/converted; so if you're not ready to do that, don't convert.
How difficult are engine mounts? An after-noon with a couple of booze breaks, a floor jack, and hand tools. It's really not that difficult to do.
I can understand the "language barrier" you speak of with that, I have picked up a number of jargon words the last couple years in college and it has helped quite a bit. The best thing was when I started getting into this offroad stuff, I never knew what anything meant when talking to people or being near people when they talk about it. My friend who got me started taught me a lot about it and got me going on my own with it all. A while back I went to another friend of his' house to borrow his welder and we were all talking about this stuff like it was a dinner conversation, what I mean by that is I was able to understand everything we talked about and that was just awesome. Never having known any of that stuff prior to starting this Jeep build, then knowing all that we talked about was a really good feeling.
What's amazing isn't that you learn the jargon - what's amazing is that you end up talking it like you've been doing it all your life. At least, that's how it feels to me...
The bearing is in there, I looked at my Haynes manual and found out what and where everything is on there. The Trans' PO gave me the flywheel, clutch disk, pressure plate, t/o bearing and the release arm slave cylinder, plus the trans and t-case and associated shifters. It seems to be in good shape, but might as well replace it while in there...
Pilot bearing, I presume? If the pilot will fit, you can probably keep using it until you have to service the clutch next. If it won't fit, then get the one I mentioned that will.
That is cool. I do indeed lol. Not sure why, or if it is supposed to be there, but there is a plate screwed to the transmission tunnel... Kind of odd it seems to me, but could just be me. Also, I was looking at the donor driveline tonight and there are 2 wired connections on it. One on the trans and the other on the t-case. The trans one is 2 wires, and the t-case is a plug mounted to the case. What is the second one for? I tried to look at the ba-10 to try and figure out what was what, but crawling under it in the state it is presently in... I will wait to do that lol.
Does that plate have a rubber membrane in it that the shifter goes thru? That's a "weather dam" - removing it will get you splashed once in a while.
The two-wire connexion on the transmission should be the reverse lamp switch.
The two-wire connexion on the transfer case is probably the "mode indicator lamp" switch - but you can probably remove it and move your OEM vacuum switch over until you get quit of the front axle disco.
I will see what I can do locally. The clutch disk and pressure plate honestly seem like new, friend of mine who knows transmissions better than I said the same thing. To save a bit of money, could I just do the clutch disk? Or would that not be recommended at all? I would rather use what I have, I really am low on funds right now so... I will ask the clutch friend about it when he comes over next time.
If the iron friction surfaces are good, yes. If the composition friction surfaces are good, scuff them up with some 320-400 grit emery and throw it in - you'll be fine, as long as there's plenty of material left on the clutch plate. Just make sure there aren't any blue spots or clusters of cracks on the iron (that's "heat checking" - and the only proper fix is replacement at that point. It's just something you should inspect for out of hand
any time you have the clutch torn apart.)
Now onto an interesting little fact here... I looked at the MC tonight and I think it may have already been replaced. Someone here already mentioned that the 88 one should be one bolt and a one piece plastic line to the SC. Well, my setup appears to be 2 bolt MC, and the line to the SC is part rubber and part steel. Any idea what to make of that? lol. I was kind of at a loss when I found that lol. lI guess I will have to pull the MC and line and take a closer look at it to verify the parts correctly.
Hm. Mine is still OEM, and it's a two-bolt with the rubber/steel line and 1/4" SAE flare fitting. If it was the plastic (probably Nylon) line, I'd have changed it out years ago. There's no pressure booster on the clutch, but the pressure in the line can still be signficant - why take chances and cheap out?
