NCSUcherokee
- North Carolina
So as I am attempting to put on some new leaf springs on the jeep I ran into the all too common problem of the bolt breaking free inside the frame, so I cut out a slot and put a wrench on it, the only thing that succeeded in doing was rounding the nut off.
Since then I have tried to:
Lube it
Heat gun it
Torch it
Grind two sides flat and get a wrench on it
Vice grip it
Sawzal it
and more...
Maybe tomorrow will bring more luck, but if it doesn't, does anyone have a suggestion about how to get this nut off and out of the frame rail?
Lube it
Heat gun it
Torch it
Vice grip it
Sawzal it
and more...
