- Atascadero, CA
ok take out the 20 pound sledge hammer sit in your jeep and bang on the frame thats the kind of sound it makes
Shomsky462 said:ok take out the 20 pound sledge hammer sit in your jeep and bang on the frame thats the kind of sound it makes
yeah it was a while ago that i checked it. the interior is stripped now and i cant (comfortably) drive it. ill check it some other timeGoatman said:It is VERY hard to diagnose a noise with as vague a description as we have here.
DaffyXJ said:I liked what Goatman said. Is it consistant with wheel speed, RPM, or just a random noise? The sledge sound, if not engine mounts, could be the track bar frame side bracket. When loosened, they make quite a racket.
I have a ratcheting sound (consistant with RPMs) from the XJ when going up hill. Thought this might be the type of noise you where refering to.
I went through the front just today with no joy. Back lash is good, Pinion preload good, all the ring gear/pinion teeth still there, front drive shaft okay. So my issue is probably the T-case chain slap. But might look at motor mounts also.
If it's loud like a hammer hitting metal, check the track bar frame side bracket.
