waggy- which volvos? any way to tell if they have the tracloc without tearing into it? the yard i go to a lot has a ton of older volvos and this would be a nice pickup if i can find one
older volvos have rear D30's in them and some of them came with factory trac locks , keep your eyes out at the wreckers and pick up some cheap extra front end traction ..
just to clarify something, I DO NOT RECOMMEND the volvo diff, I am a volvo guy and although at some point every volvo guy considers swapping to them, they are so much weaker than the open diff that if you need the trac lock, you'd just break it anyway, and the open volvo diff is still really weak, usually the d30 volvo guys jack parts from jeeps because volvo took the d30 and did a lot of their own changes, although it is true usually the diffs and some versions of gears swap
its a spring loaded centrifugal toothed pawl. basically, if one wheel isn't spinning, once enough rpms of the axle are reached the toothed pawl catches instantly, and catastrophically in most cases, locks the axles
it was designed for low powered engines on snow, where lock up would basically cause equal spin, it was not designed for power or vehicle weight anywhere near a jeep, and it was deffinetly not made for big tires and low gears and t cases
put that same plan into action on pavement or wheeling, and basically it lets one wheel slip until your motor is up in the revs and the other wheel really has some momentum, and suddenly BAM, instant tooth shattering lockup
things get really fun when those snapped off teeth find their way into the ring and pinion, which considering the life of a jeep axle, will probably happen much faster, a sedate volvo can break off teeth until they pile up in the case and reach the gears, I imagine one tooth bouncing around would probably do you guys in, then you need a new diff, new gears, and possibly a whole new housing depending on the carnage
