Northern Pride
- New Hampshire
I have skyJackers 8" lift on my 98 XJ. Everyone who has there lift knows there version of quick disconnect is junk. I bought some JKS Quicker Disconnects but are good for up too 6" inches of lift. So I bought some two inch spacers from Rubicon Express to lower the sway bar.
The problem is on the passenger side, the shock on the cross member is in the way of mounting the qucker disconnect on the passenger side. I'm thinking the best way around it is to fab a bracket that will mount the shock closer to the center of the vehicle and then getting a shorter shock if needed. That will allow me the room to slide the disconnect off when off road. Other wise when trying to slide it off it will hit the shock not allowing it to be disconnected.
I thought about mounting the quicker disconnect on the out side of the mount but I believe that will put it at too much of an angle to the sway bar.
Anyone run into this problem? and if so how did you get around it?
Thx
Thx
