jeeptec
- atascadero california
does anyone know if the tru lock electric locker from a JK 44 will fit into a XJ 44. also what about the ring and pinion. i know the XJ uses shims for preload on the pinion. and the carrier is shimmed betwwen the bearing and cae. the JK uses a crush sleeve and the carrier bearings are between the housing and bearing . much like a model 35.
