SexJ1988
- Central IL
Yep, it sounds scary as hell till you get use to it. You can do it slowly over time if you wish. I did at first, but I think I just dragged it out longer.
BTW, I wonder what oil you used versus what the PO used? I have heard of changing brands causing the sticky lifter noise!!!!!
Me, I would solve the #1 and #2 cylinder No-fire-miss-fire issue of possibly not firing before I pushed it!!!!!!! As if there is raw gas going into cyl #1 and 2 that stays unburned it can be drying out the lube points and adding to the lifter noise!!!!! And thus a good reason for not pushing the RPMs up yet.
At least you have the MMO in there now. But once you know that all six cyls are firing properly and it runs at a steady idle, do not let the lifter noise keep you from working the RPM systematically higher till the lifters free up. Nothing wrong with letting the engine run a few times and letting the MMO soak in first before pushing the RPMS up to the sweet range that forces the lifters to free up finally and quite the engine back down.
Replacing fuel filter tonight as precaution, and going to make sure injectors are plugged correctly, and making sure firing order is correct. Other than that going to check grounds and hope it runs right.
