Muad'Dib
- Bend, Oregon
I got the throttle body that im using now from a Junk yard jeep. It looked like it had a slight engine fire... nothing looked extremely burnt, but you could see the shit from the fire extinguisher.
I took it off the old jeep and took it home.
When i got home, i completely dissambled it. I individually cleaned up each peice. I made sure the valve was flat and everything cleaned up real well. When i initially installed everything, i didnt have this problem .. its only recently that i have.
Ill try the battery thing the next time i have the hood open... and see what happens.
As far as the +B latch relay, i guess its a stong possibility that something is wrong with the circuit. I replaced the relay here with a SPST 4 pin, i have BOSCH replacements on order. Its doubtful that after replacing the relay that its not working again, unless like i said there is something wrong with the circuit.
The above also makes since because lets say if i start the Jeep, and then shut it off (or it dies) then restart it, the second start (now that i did everything in my previous post) is just as it should be. RPM's jump to approx 1500, and then down to ~750.
Whatcha think?
Damn i should of thought of this.... ill give it a shot tomorrow.Ecomike said:As a test try giving the gas peddle just little gas (actually air) before and during the start up cycle to see if the problem is too little idle and start up air supply. IF taht works then keep focused on the IAC-throttle body and idle stop screw as the problem-solution.
Whatcha think?
