- MilkyWay Galaxy
You may be trying to restart too soon? There is timer that resets the ICM to a start position, probably takes a few seconds, and my daughters Saturn needs to be in the run mode for a bout 10 seconds before you crank or it will not start. I figure it is a computer / sensor control valve reset time delay involved. Renix 87-90 likes to be on while the fuel pump primes for 3-4 seconds before cranking.
I would focus on the MAP sensor subject top to bottom next. Then see what all it does. IIRC the later years were notorious for hidden vacuum tubing leak near the throttle body that feeds vacuum to the MAP sensor. If the MAP does not get immediate accurate vac data it will cause most of your problems.
