- Roanoke VA
that is a really interesting rear axle setup they use. It appears to be a full floating shaft with a unit bearing that bolts on outside it - almost like a cross between a conventional full floating axle setup and the halfshaft / bearing configuration on an independent suspension.
My parts catalog indicates 3 gear ratios are available for the frontend (3.07, 3.55, 3.73) but they aren't really the best ratios, so that's no help... it is too bad no one has determined the important specs (hypoid offset, ring gear inner diameter, outer diameter, bolt circle diameter, offset from ring gear mounting surface to pinion centerline, etc) and started making 4.10s, 4.56s, and 4.88s for them. I guess it's probably somewhat of a niche market.
Yes the front diff is manufactured by AAM,(American Axle and Machine). Its a tough diff just no after market support. Yep, I'm waiting to find a XK rear axle n the JY and try to get it cheap. I wanna play a little.
