czb83 said:I'm using a narrowband sensor right now. Once I get it tuned nice and working without flaws I plan on adding a turbo, at which point I will add a wideband sensor. Probably an LC-1, since they can be had for like $200 new. btw, its a stock 4.0 right now.
Dont forget 5-90 :wantyou: This weekend im going to see what I can do to figure things out but its tough with finals and all.5-90 said:Yeah, I know what you mean.
As I've highlighted above, you need to multiply the VE (real-world percentage) with the displaced volume/revolution (theoretical quantity) to get the amount of air you're actually moving. So, it's VEx241.5ci, or whatever that works out to in cubic centimetres (~3957.5cc - found my calculator.)
For more detail, I'll probably have to crunch some numbers myself, then "show my work" for it to make any sense. However, I can definitely say you're running a little lean - 15.5:1 isn't something that the computer will usually pass for cruise RPM (ideally, it doesn't go past 15.0:1 under normal operation - and should run just a touch rich, as I'd said, to avoid detonation. The catalytic converter should handle the HC and CO emissions that will result. However, the control computer tries valiantly to run at the "ideal" 14.7:1 ratio.)
Since my wife will be in New York for the week, I might tackle some of this one evening or another, and see what I come up with. If you don't see anything by Friday, would you please PM me a reminder?
BBeach said:So this is something that was done on a software program? Is so which is it and is it free to public? So basically at the 2000rpm, it calculated how much fuel it would use per hour under no to little load?
BBeach said:Say you have a jeep with 4.0, AW4, 3.55 gears, and 235/75R15 tires (right there may be a variable because they may have rated with AX-15 and 215/70R15 for that matter...). At 60mph with the 235's you'll be turning about 700revs/min at the wheel. Therefore its about 1864rpm at the engine. For every 2 turns of the crankshaft, every cylinder will have taken in air (3955cc or about 4.0L). <---Now is it taking in 4.0L or the V.E. x 4.0L? That's my first question. But since the V.E. is just a constant at the exact rpm, I can toss it in later if need be. With the 1864rpm/2 = 932rpm x 3955cc = 3686L/min which is the same as 3686L/mile of Air. To find the mass of air you use the formula M=D/V and find that mass to be 4423.2grams of air per minute assuming 1.2g/L density. Using an air/fuel ratio of 15.5:1, that 4423.2/15.5= 285.37grams of gas per minute. Using wiki's density of gas and the known mass, you find the volume to be 2.5834L gas/minute. But.....thats .6825gallons per minute and therefore 41gallons per hour....which is just a little bit wrong. :huh:
Anyone know where I screwed up and if theres somewhere where V.E. of say 60% is in effect, or that air is only 23% oxygen, or that combustion obviously isn't 100%? And if so, does anyone know how much its off by and why? I'm not sure why I'm doing this but this is what you do when you're bored.
scottbky said:So far, best mpg is somewhere between 60-65, at 25-26 mpg. It's been awful windy around here, so I've been getting headwinds and tailwinds depending which way I go. rpm is right at 1900 at 60 mph, so maybe that's the "sweet spot."
ScottB
