one bad dakota
- mn
I was having a discussion with a buddy on jam nuts. On my RK 3 link it states using loctite and failure to keep tight will void the warranty and damage threads. My old RE stuff said to use antiseize. Is this that big of a deal? If only one end of the control arm is threaded with a jam nut, I don't see how their can be much movement of the control arm length other then some minor back and forth movement at the joint end.
I certainly won't be careless about it, but it is a ZOMG moment?
