I have done a bit of searching about this, but before I start this project, I would like a second opinion.
Symptoms:
1. Squeaking noises at low speeds
2. Drivers side front tire has heavy wear on the inside edge.
3. Passenger side has even wear.
4. Light binding at low speeds combined with sharp turns.
IIRC, bad toe angle can cause the edges of a tire to wear incorrectly, but since this only affect one tire, I disregarded that. I also noted that bad caster angle can affect the camber angle, but since I have no lift, I also disregarded that. My only remaining option was that I had bad negative camber on that single tire. Apparently the camber is not adjustable on an axle of this type, Which narrowed it down to either a bad ball joint, or a bent axle housing.
Since I havn't done anything that would bend the housing at least 1*, I would have to guess it is the ball joint. This doesn't seem to explain why it squeaks and binds. So I am thinking of replacing the U joint and possibly the hub bearing.
Does this seem reasonable?
Specs: Stock D30, no lift, no locker. 4.0,aw4, 231.
Symptoms:
