The XJ needs lower gears. 4.11 would hit the spot and is found in 2.5L Cherokees and wranglers.Stronger Ujoints are also a plus. I figure more TJ owners swap out the D30 front than XJ owners so it might be easier to find one. In terms of coil mounts and shock mounts is it the same axle? Will it bolt right in? Thanks
