Darky
- 29 Palms, CA
First remove the reasr shaft and drive it in front wheel drive to ensure that the problem is actually coming from the rear end.
did find out the source of my thumping under the floor board...the exhast hanger bushing on the side of the transmission mount had an elongated hole from the t-case drop...so I fixed that and I also too pics of the angles so I'll post those tonight
I've had that thump you're talking about before... how are your motor/trans mounts?
Your trans mount could be shot or loose after removing the tc drop.
Ok I did that with the exception of taking the rear shaft off but with the front ds off and sitting in the garage the jeep has the exact same vibes...doesn't that pretty much say it's in the rear...especially since
most
of the vibes are during acceleration only???
Ok so I removed the rear ds and vibes went away just like I thought...so should I remove the shims? What about on Tom woods' site where it says the pinion should be pointed straight at the ds when using a double cardan shaft? Or does it not factor in an sye??
You're correct winkosmosis... though more specifically it's supposed to be 1-2 degrees below being parallel with the driveshaft. That only goes for leaf spring suspensions, for coil based suspensions the pinion angle should be the same as the driveshaft angle at ride height (no spring wrap to compensate for) though that's probably inherently obvious to anyone building a linked suspension.
