- Maurertown,Va.
Did a thorough check of the vac line routeing just a few minits ago during an oil change. 96 XJ
Vac comes off intake manifold thru check valve>firewall around back of engine and under the area of the AC lines,Washer bottle and the hot water control valve.There is a T-fitting with a small line that has a check valve which turns and goes into the firewall at the same place the vac line comes out to the hot water valve.
Main line continues to vac blimp--
HTH
Wayne
HTH
Wayne
