G60GTI
- Western New York
98 xj. All of the searches i did seem to focus around the fan cutting out, and then no more air coming out of the vents, going to the defrost vents(vacum related). Mine is a bit different. Last winter I had no problems, blasted heat all winter and barely noticed the fan coming on. Spring rolled around, and knowing that my AC did'nt work, I put a full charge in it. Worked for a couple months pretty well, but slowly became less cold air, probably a small leak. Then one day I turned on the AC and noticed the fan coming on and then shutting off about every 5 seconds. Said F it, and didnt use AC anymore. I had to use the heat the other night and it is doing the same thing, 5 second on, 5 seconds off, but air is still flowing well through the vents. It doesnt matter if I am idling, cruising at 30 or 75, It is always doing it.
Any ideas? It's really annoying, plus I would really like to avoid burning up the motor. Thanks.
