I picked up the aluminium from Home Depot. Inexpensive and easy to form. A bench vice and some angle iron to extend the jaws is all that is required. As my vents are angled, I had to make the pans to reflect the differences. Fortunately, it was only a matter of making the bends in the opposite direction to accommodate the vents.
Here is a top side view of the vents:
[/URL][/IMG]
As to the placement of the vents, there are a ton of opinions out there. I wanted low speed extraction so they sit closer to the cowl...
In the past, I have used the "tape chunks of yarn to the hood" method. Cut pieces of yarn to about 1" in length and then tape them, on on end, onto the hood in a pattern. I use a 4" square but it is not all that important. More is better but don't get silly...
Then, as you drive, the yarn will start to point in the direction of air flow. Ideally, it will stand up. The place where it stands up at your
target vehicle speed is where the vents go for best heat extraction
at that speed. The pressure wave off of the windscreen will make an appearance once the speed gets up.
As it turns out, there is not a location that works universally.
This is a very Old School technique. But, considering I am well north of 60 years of age, what do you expect?
The only change I have made in the technique for that last 5 decades is to use blue painter's tape as the adhesive is so much easier to clean off of a hot hood. Some things just work.
