good advice, forgot that...jshwank said:And remember "DON'T" tighten anything down until you have all the bolts for the drop brackets and braces started into their correct holes. With the unibody, your holes might be off just enough that if you start tightening one part down, you might not be able to get another bolt in. Then you have to start all over!
Good luck...
Yep, that's the biggest tip you could get.jshwank said:And remember "DON'T" tighten anything down until you have all the bolts for the drop brackets and braces started into their correct holes. With the unibody, your holes might be off just enough that if you start tightening one part down, you might not be able to get another bolt in. Then you have to start all over!
Good luck...
YJs don't have control arms. you must be talking about a t-case drop, that is very different and much easier.davidt said:did one on a yj last weekend, only took us about an hour, do yourself a favor and get air. Get a tranny jack if you can so you can lower the whole crossmember to the same level. Anyway, good luck and let us know how it goes!
Try hereBig Red said:I going to be installing these on my bro-in-law's XJ. He has about 6" lift with non adj upper and lower RE control arms on his 91'. I'm swapping in a non disco 297 u-jointed dana 30 open with 4.88 gears front axle and a rear early bronco ford 9" with 4.88 gears, a spool, and 31 spline Moser axles. Does anyone have a write up on how to install the drop brackets with the braces from RE? I didn't take a look at it too much yet, but isn't it pretty straight forward?
Troy
Very impressive, installing a part on a Jeep that it isn't nade for...davidt said:did one on a yj last weekend, only took us about an hour, do yourself a favor and get air.
yup, my bad brett, I am sooooo glad you are always there to correct me, btw, thanks for the advice...BrettM said:YJs don't have control arms. you must be talking about a t-case drop, that is very different and much easier.
