Leaf springs and axle wrap go together like--well, you get the picture.
Recommended rear pinion angle is negative 1.5 to-2 degrees because, with leaf springs, you will get axle wrap. Throw on big tires, and low gears and , walla, axle wrap big time. Use stock leafs in conjunction with low gears and big tires, and Kattie bar the door.
Traction bars are not a band aid--they become a necessity when torque to the rear axle is increased significantly. After-market springs are generally significantly stiffer than stock units, thus you won't notice the wrap as much, but it's still there, and, if you drive hard, it will eventually take its toll on springs and u-joints. Wheel hop is caused by axle wrap--that's why the go-fast guys use traction bars, or link the rears, like Grand Cherokees.
