WraithKWK
- Spring Valley, Ca.
If there are any San diego guys that know the renix 4.0 ... I could use some help.
89 4.0 Renix
high idle 2k so I broght it down with throttle plate screw
High idle again
and or
strong miss/Hesitation when axcellerating from idle ( started all of the sudden wont go away)
plugs are old but functioning
tried to check tps
used this site for info on how to do it http://autorepair.about.com/library/faqs/bl232i.htm
Supply voltage 4.68
output voltage 4.22
I thinnk the info was wrong cause my ratio was 0.901 instead of the 0.30 that it recomended. when i tried to correct it my idle shot to 2k+ constant miss/studder. I set it back to origanal rms back to 2k ruff idle and constant studder. smacked wires abit then it went back to 800rpm with constant studder
I'm going outta my mind
89 4.0 Renix
High idle again
and or
tried to check tps
Supply voltage 4.68
output voltage 4.22
