ChipsXJ
- Broken Arrow, OK
Freezing here with snow on the ground.....HELP!
I searched but did not find this exact issue with any resolution.
1992 XJ 4dr with TILT steering.
No previous issues with steering wheel lock/ignition switch.
key would go in.
key would turn to ACC
key would not turn forward to start.
steering wheel NOT LOCKED and will not lock.
removed the ignition lock the hard way...in pieces thru its mounting hole.
even with the lock removed entirely, still will not turn.
Is it the ignition switch or is there some linkage in the column that is more likely the culprit?
Thank you very much.
key would go in.
