Markos
- Seattle, WA
I've got coolant spraying like a squirt gun, right where the cylinder head butts up against the firewall. The coolant is squirting right at the firewall, then dripping down by the tranny pan. I'm guessing that it could only be the head gasket.
Assuming that it is the head gasket, is it possible that I warped the head? This seems much less likely with a cast iron head, but I want to know what I'm in for. Where exactly is the coolant temp sensor located? My engine temps are hovering right in the 210 mark, same as usual. My fear is that the head is starved for coolant while the sensor goes about its business. Hopefully that isn't the case.
Any thoughts?
Any thoughts?
