I have a pequliar problem.
88manche
Portland, Oregon
I know i probably butchered that spelling, but oh well.
Heres my problem. on my 1988 MJ, no matter what speed, no matter how hard i turn, how much weight is in the truck, or what tires are on it, I get a grinding/whining/growling noise from the drivers side of the front axle. Its a dana 30 from a 96 cherokee.
What are some causes?
The wheel bearing is nice and tight, it doesn't wobble, and the ball joints are good. that axle shaft u joint is good too.
Well that covers just about every suspension piece... Maybe you should recheck those?
I would bet its the Hub assembly. It may look ok on the outside but its hard telling what is going on inside of it.
Uhhh, Ian........ What suspension peices did he mention? :D
Sounds like a wheel bearing/unit bearing. It will make noise long before it gets loose. If you let it go long enough to get loose you're in trouble.
