Since when did the Manual Transmission have a dipstick tube ?
Look on the drivers side of the trans. You'll notice 2 plugs. One high on the left side (front) and one lower on the rear of the trans.
Remove the upper one first, and then the lower. It will drain much faster for you , since when the old fluid goes out, air will get suck into the upper hole.
give it a little bit, and then stick in the lower plug and fill from the upper.
Get the right fluid too. Check your owners manual...I belive it has to be rated GL-5.
