Agreed, they sorta invented them. I'll use cheap cheap cheap ones already installed on a shaft from the junkyard (inner shaft, U-joint, outer shaft, and unit bearing all together cost me 30 bucks), but if I'm going to mess with that spindle nut, I'm using a new Timken unit.
I didn't even realize mine were bad, I pulled the whole shaft assembly out to replace with a junkyard one because I was too lazy to screw around with U-joints in 13 years of northeastern rust, glad I did because the shaft ears were pretty much rusted beyond repair, joints frozen in, and unit bearings had 1/16" of play in them (didn't notice this till I brought it all inside.) Then that grinding howling noise that had been developing recently and I hadn't bothered to track down sorta disappeared :looney:
