HP D44 front axle
DutchVDub
Milliken, CO
I'm selling a front high pinion Dana 44 axle out of a 1972 Ford F100. It's an open knuckle, drum brake axle with the welded on radius arm wedges. It has the original 3.50 gears in it, and still has the drag link, trac-bar, and tie-rod attached.
I'm asking 400$ for it, this is the perfect bolt in upgrade for an Early Bronco or older F100. It's also a great axle for putting into a Jeep or rock crawler as the welded wedges are easy to remove and it has the very strong 2 1/2" outer diameter 1/2" wall tubes.
https://denver.craigslist.org/pts/6252383396.html
