Lowrange2
- Abbeville, SC
I preferred cutting the bushing down. There's enough steel sticking out of the rubber to cut on without touching the rubber. (As you can see in my pictures.)
CAs came in today. Do you think I'll need an alignment? Mixed reviews when I did a search. Obviously I will be able to tell after get them on my how it drives and what not.
But I'm wondering if I should replace them on the ground to help avoid an alignment. Is that even possible?
If you are not opposed to it. You cal remove the plastic bumper end caps. A few bolts removed and more clearance!Score. You rock. I was going to go to the junk yard today. But got lazy. Good thing. Because even if I happened to find any, they would be a pain to pull, the yard would probably charge me 25 bucks. And the bushing wouldn't be new.
Started doing that today Gary. On the front bumper. Turned out ok I think. I'm gonna post pics In the next few days when I get it back together. I'm gonna have to trim the rear bumper plastic also. Just going up the curb today almost ripped it off
When I previously installed WJ LCAs on my heep the PO hadalready trimmed them a bit. I still bent out the bracket on the axle side just a bit for ease of install. When you tighten the bolts, with the weight of the jeep at ride height, it will pull the bracket sides back in.The write up we have posted on here suggests bending out the bracket a little bit more as opposed to cutting the bushings. But you like the bushing cutting method more?
Haha yea I wouldn't dare, it'd probably be easier to replace the whole arm before messing with those nasty bushings. Why haven't you tried the WJ arms? They are highly desirable for me at this point to fit my tires. Which I can tell they will clear if I ever get them bolted upI don't know what to tell you about the WJ arms, never tried them. I can tell you that replacement bushings in stock arms will put up a fight. Your old ones do look pretty toasty.
Yea Instagram shout!Here's an idea of what they will look like:
Another issue is I can't seem to get the oval bushing side, frame bracket, up in the bracket far enough. It seems to hit its top edge on the jeep.
Really? I read this on another site and of course I believe everything I read.
Take a look at post #24 in this thread, you can see what needs to be trimmed. The first pic shows portion that is hitting on yours trimmed off a bit.Another issue is I can't seem to get the oval bushing side, frame bracket, up in the bracket far enough. It seems to hit its top edge on the jeep.
I don't think my factory arms have ever hit the shock mounts. Do you happen to have any pictures of your trimmed shock mount. I'm wondering how much is appropriate to trim before any integrity is compromised.
He's talking about this.
I had to make that cut as well. I chose to run the round bushing at the axle and the oblong bushing at the body. I don't see why it'd hurt to go either way.
The only other disadvantage to WJ arms is that they hit the lower shock mount even faster than OEM arms. Trim that back while you have the arms off.
