CaliXJ
- Oceanside, CA
Is this mod. something US 2 door owners shouldn't do? Or only to be done after frame stiffeners?
True but the doors still aren't structural. doorless or not stiffeners are a good upgrade anyways.2 door like to twist a little more. No B pillar on a 2 door
These were the stepe I took
1: Leave windows up
2: unhook wiring from inside kick panel
3: remove door helper pin and just jam the door helper into the door
4: cut hinge pins in half with dremmel (heavy duty cutting wheels)
5: pry whats left of the hinge pins out with breaker bar
6: get 3/8 bolts from home depot
7: cut bottom half of hinge clean off
8: weld bolts in but leave the top bolt shorter for easier door removal
9: paint any fresh metal
they pop on or off in seconds...
if its raining- doors on
if its not - doors off
Did you take pics of this? I have seen it done but I want some pics to make sure we don't screw it up.:laugh2:
-Alex
I took the dorrs off my 87. and it was really easy to put them back on. just dont try to do it in the dark lol.
plasma > cutoff wheels as far as cutting the hinges go. takes 30 seconds per door instead of 20 minutes.
Bahaha I guess if you are spinning the cutoff wheel on your finger it might take 20 minutes. Plus, plasma $$$ > $$$ cutoff wheel.
