JeepNovice
- Gardner
I was toying around w 4wd I wAs not moving just put it on drive and put in 4H then put truck in neutral then shift to neutral then drive and then clunk! For 4l. After that I went in reverse order and it would not shift back to 2h and it made a clunking noise and truck would not go on drive or reverse and it just acted as if it was on neutral. So I put e brake and shut off ignition then was able to put it in 2h. Started it up again and it would reverse n go on drive. What s this about? Is this a transmission issue or t case? Or simply bc of my stupidity bc I wasn't moving while doing all the shifting?
