klonestar
- White Mtns. New Hampshire
Did search and found old threads (03'-04') on adjusting linkage (cant find em again now) but they did not say if it was for standard/auto and did not explain well for a newb.
Mine will not go into 4Low. Seems to stay in a neutral function. Both 4highs work well no prob.
I really need step by step info on how to.
Like if I jack up w/TC in low and loosen linkage nut how will that alone change position of the clamp/rod location?
Read somewhere here that if the "low4" adjustment doesnt work can try in 2wd to adjust and now just more confused than ever.
When I put into 4low now nothing happens, no noise, nothing. Just freewheeling as if in neutral.
I did try all methods of finesse as far as different ways to try to coax into gear and nothing helped.
Is a 90'xj auto 242.
Many thanks,
Ken
Many thanks,
Ken
