I suggest staying with the 30's until you wear them out and focus on more important things like rock rails, some armor and a D44 rear. If you are running primarily mud then you need big tires and big hp, way bigger than you are going to run on a 3" lift with a Dana 35. If you run more trails with rocks, logs and streams then armor, rock rails and waterproofing are more important. There will always be a rock or log that will rip out your transfer case, smash your rocker panels and turn your 15 gallon tank into a 10 gallon tank. Most folks make the mistake of going for big tires on stock gears with no armor or extra coolers and then blow up their tranny and destroy everything underneath before they get religion and armor up, add coolers and gear down.
Running open/open on 30's will make you a much better driver and will allow you to embarrass everyone on 33's and 35's with lockers when you carefully crawl right past them or offer them a strap. You can do a lot on 30's, think carefully about how you drive your rig and what will really make you weekends more enjoyable/reliable.
John
John
