Well got a new distributor to put in and the gears on the older one were even worse, nearly gone, probably wouldn't have lasted a day. The new distributor definately works better. But I'm afraid that I might have some "Cam Walk". I read a post that if you have over 58lbs of oil pressure your cam will move forward and eat the gears up. I have a HV oil pump and I'm running about 58lbs at cold start up at idle and about 45lbs warm idle. Its about 60lbs at cruising speed give or take 5lbs. I'm running 5-30 and I'm not sure about running a different weight. Does anybody have suggestions about cam walk? Can I change the spring on the cam button? Or do I need to change my oil pump? Oh and I'm running renix injectors but thinking about trying the HO ones just see how it will run. Seems I'm still lacking in power at cruising speed and using A/C.
