Miller88
- Syracuse NY
My 2000 XJs 4.0L was pretty quiet when I got it - the quietest 4.0 I've had.
Over the past few years, it's got pretty chattery. It didn't sound like a broken / cracked flex plate - I checked and the flex plate was not broken and the bolts were not lose.
Hot idle:
https://www.youtube.com/watch?v=Emcfq3BnlzY
Hot restart seems to be the worst:
https://www.youtube.com/watch?v=KYuny4UQM44
To me, it sounds like a broken piston. Which makes sense - it's a 2000, so it is either going to break a piston or crack the head. My plan was (and still is) to run it until it self-ventilates then find a 99 and older engine to swap in.
I was doing some snow wheeling. I have skinny tires. The only way I could go at all was to use a lot of wheel speed. There were a few times where I had it bouncing off the rev limiter - and a few spots where I sustained 4000RPM for a minute or two straight to move.
After that, the engine was whisper quiet. Even on hot restart!
The chatter came back again. So I put it in 1/2 and drive around at 35MPH in 1st gear for a few minutes. Engine was quiet again.
Oil pressure is good. Seems to be too high pitched of a noise to be a rod knock (same pitch as piston?).
But usually high RPM operation causes the pistons to let go if they are broken.
Confused!
Hot idle:
Confused!
