Hi gents, I looked in the OEM section for a solution but couldn't find my exact symptoms, similar...so I'm posting here for y'alls help.
I had a normal drive to work except for when I put jeep in park the idle speed jumped to 1500 or so. Turned jeep off and went inside. Several hours later I started her up to go to grocery store(cold start) and no issues except when I parked at grocery store, high idle again. Turned her off, bought my stuff and drove home, no issues on start up or park this time.
I was thinking maybe TPS, IAC-pretty sure it's not vacuum cause I checked this already with O-Gauge and fixed my heat issue. Anyways, as mentioned earlier all the idle issues ppl on forum were having dealt with TPS or IAC but can't find anyone whose had the issue when in park-normal driving seems fine.
Also, how long should it take idle to decrease from 1000 startup to 650-750? I know I'm prolly forgetting something, been a long day. Thanks in advance guys! Just wanted to hear some opinions before I go cleaning/testing and possibly screwing up the electronics.
Scott
Scott
