Hi-beam + aux lighting
POSJ
How would I go about wiring in some extra lights into my existing harness? I want to be able to flick on my high beams and in turn, have some aftermarket foglights/driving lights turn on aswell. I don't want another extra switch to flip just to get the lights on. This isn't on my Jeep otherwise I would be all for it. It is on my 01' Dodge 2500 CTD. thanks in advance.
Tyler
You would have to use a relay.
Terminal 85 would go straight to ground.
Terminal 30 would be fused and go straight to the battery, fuseblock, or power distribution center posts.
Terminal 86 would tap into the high beam wiring. Which would be positive.
Terminal 87 would go straight to the lights which you wish to power.
This is all assuming that your truck is positive-switched. It should be but I am not sure!
Good luck.
