muddeprived
- PA
I am removing my stock springs for my lift and ran into a problem. I cannot get the passenger side front spring bolt out because the metal sleeve in bushing is seized to the bolt and when i turn the bolt, it's turning with it and pushing the bracket out. The bolt cannot come out by itself. I tried turning it as far as i could but the sleeve is pushing the bracket out very far. What are my options? The only thing i can think of is cutting the leaf spring wrap off, then cut the bushing off so i have access to the metal sleeve and then cut that off? I don't have anything small enough to get between the bracket to cut the metal sleeve. Maybe a dremel but not sure.
Every other bolt came out with no issues. Even the shock bolts came out with the impact very easily.
