black sunshine
- Alaska
i have noticed a knock in the rear of my engine. not sure what it is. the noise occurs when you tap the gas then let off, at the point where the engine drops back to idle it makes the knocking sound. it only happens when the engine goes to idle and it only knocks once or twice then the noise stops. it does it while in gear or in neutral but only at idle and only one or two knocks.
i have removed the oil pan and checked to make sure no rod cap bolts were loose. no real signs of wear on the engine so far. i drove it 60 miles the other day and isnt noticeably worse. any suggestions besides doing what we would all LIKE to do and shit can the 4.0 and throw in a 4.7? :speepin: (dreamin)
