2000XJSPORT
- Illinois
My steering stabilizer went out today and I had to replace it. Everything went in fine and it works fine, but now there is a knocking noise when I turn the wheel from all the way left (Knock Knock) to all the way right (Knock Knock). Also does it when I make sharper turns. I greased all the point and made sure the bolts were torque to spec. Also when I lift up the front end so the tires are off the ground. The noise goes away. I'm not sure where it is coming from. Can anyone help?
